The 8Sinn Cage and Top Handle Pro for Sony a7R III is a CNC Machined, anodized aluminum full-armored cage with integrated accessory mounting holes and an adjustable top handle system. The cage is suitable for use with the Sony a7R III, and features a built-in cold shoe as well as slots for a hand strap of your choice (not included). Threaded 1/4"-20, 3/8"-16, and M4 mounting holes allow you to mount accessories without stressing your camera's body.
The Top Handle Pro attaches via a NATO rail and clamp system, making it easy to attach and remove from the cage. In addition, the Top Handle Pro can be mounted either forward- or rear-facing. It features two cold shoe mounts and multiple 1/4"-20 and 3/8"-16 threaded mounting holes. The cage has two small raised tabs that hold the camera in place and prevent it from twisting. Access to all camera functions, as well as battery and media doors, is maintained. An included HDMI cable clamp mounts on the side of the cage and is adjustable to fit your HDMI cable.
The formfitting cage incorporates front tabs that prevent the camera from twisting.
The cage features a variety of 1/4"-20, 3/8"-16, and M4 threaded accessory mounting holes. This allows you to mount accessories without stressing your camera's body.
The top handle features both a top- and forward-mounted cold shoe mount. It also features 1/4"-20 and 3/8"-16 threaded mounting holes.
You can slide the Top Handle Pro back and forth while it remains mounted to the cage. This allows you to adjust the position for balance, comfort, and clearance.
The included HDMI cable clamp helps prevent accidental kick outs of an attached HDMI cable.
$308.00Price
Brands
Cages
