The 8Sinn Cage and Top Handle Scorpio with 28mm Rosette for Sony a7RIII is a CNC-machined, anodized aluminum, full-armor cage with integrated accessory mounting holes and adjustable top handle system. The cage is suitable for use with the Sony a7RIII, and features a built-in cold shoe as well as slots for a hand strap of your choice (not included). Threaded 1/4"-20, 3/8"-16, and M4 mounting holes allow you to mount accessories without stressing your camera's body.
The top handle attaches via a 28mm rosette system, allowing the top handle to be mounted in multiple orientations and not just forward- or rear-facing. It features four cold shoe mounts and multiple 1/4"-20 and 3/8"-16 threaded mounting holes. The cage has two small raised tabs that hold the camera in place and prevent it from twisting. Access to all camera functions, as well as battery and media doors, is maintained. An included HDMI cable clamp mounts on the side of the cage and is adjustable to fit your HDMI cable.
The formfitting cage incorporates front tabs that prevent the camera from twisting.
The cage features a variety of 1/4"-20, 3/8"-16, and M4 threaded accessory mounting holes. This allows you to mount accessories without stressing your camera's body.
The Scorpio Top Handle features two sets of top- and forward-mounted cold shoe mounts. It also features 1/4"-20 and 3/8"-16 threaded mounting holes.
The Scorpio Top Handle also integrates a 15mm rod clamp that secures an optional 15mm rod perpendicular to the handle, providing additional accessory mounting opportunities.
The included HDMI cable clamp helps prevent accidental kick outs of an attached HDMI cable.
$308.00Price
Brands
Cages
