The Cage for Panasonic S5 with Black Raven Top Handle combines a formfitting protective cage with a matching top handle that you can position in one of four directions. The Black Raven top handle mounts on top of the cage via the 3/8"-16 threaded mounting hole, and it has integrated pins that mate with the anti-twist divots around the 3/8"-16 hole. This provides a solid connection between handle and cage, preventing twisting when assembled. The pins and divots allow you to position the handle so it extends either behind the cage, in front of it, or to either side.
The cage features numerous 1/4"-20 threaded accessory mounting holes, and it protects your camera from the stress of attaching accessories. Along the top of the handle run eight 1/4"-20 threaded mounting holes, as well as a 3/8"-16 threaded mounting hole with ARRI-style anti-twist divots and a cold shoe. The front of the handle incorporates an additional 3/8"-16 threaded accessory mounting hole with ARRI-style anti-twist divots.
8Sinn Panasonic S5 Cage + 8Sinn Black Raven Top Handle
- Formfitting Camera Cage
- 19 x 1/4"-20 Accessory Mounting Threads
- ARRI-Style 3/8"-16 Anti-Twist
- Maintains Access to Camera's Hot Shoe
- Built-In Strap Slots
- Orientable Aluminum Top Handle
- Front Threads for Optional Accessories
8Sinn Cage For Panasonic S5 Specs
Accessory Mounting Cage, Top: 6 x 1/4"-20 Thread, 1 x Anti-Twist 3/8"-16 Thread
Cage, Sides: 13 x 1/4"-20 Thread
Cage, Front: 6 x M4 ThreadCamera Mounting 1/4"-20 Screw Tripod Mounting Cage: 1/4"-20 Thread, 3/8"-16 Thread Shoe Mounting Cage: 1 x Cold Shoe Rosettes None General
Support Type Cage Grip Type None Camera Compatibility Panasonic DC-S5 Dimensions 5.8 x 4.1 x 2.6" / 147 x 105 x 66 mm Weight 6 oz / 170 g Packaging Info
Package Weight 0.71 lb Box Dimensions (LxWxH) 9.2 x 5.6 x 3.1" 8Sinn Black Raven Top Handle Specs
Grip Type Topside Handle with Cheeseplate-Style Handle Rotation Yes, 360° Built-In Controls None Mounting
Attachment Method Attaches via 1 x Built-In ARRI Anti-Twist 3/8"-16 Screw Accessory Mounting 2 x ARRI Anti-Twist 3/8"-16 Thread
8 x 1/4"-20 ThreadShoe Mounting 1 x Built-In Cold Shoe Slot Rosettes None Rail Mounting None General
Construction Aluminum
