8Sinn Cage for Sony a7SIII
The 8Sinn Cage for Sony a7S III is a CNC-machined, anodized aluminum full-armored cage with integrated accessory mounting holes. The cage is suitable for use with the Sony a7S III and features a built-in cold shoe as well as slots for a hand strap of your choice (not included). Threaded 1/4"-20, 3/8"-16, and M4 mounting holes allow you to mount accessories without stressing your camera's body.
The cage has two small raised tabs that hold the camera in place and prevent it from twisting. Access to all camera functions, as well as battery and media doors, is maintained.
*HDMI Cable Clamp Not Included
8SINN TOP HANDLE PRO
The 8Sinn Pro Top Handle is designed for use with cages equipped with 1/4"-20 threaded mounting points. The handle attaches via a 60mm NATO rail with right and left adjustment, making it easy to attach and remove from the cage. In addition, it features two cold shoe mounts and multiple 1/4"-20 and 3/8"-16 threaded mounting holes. A 15mm rod can fit through the handle.
8Sinn Cage for Sony a7SIII + Top Handle Pro
SKU: 8-a7SIII C+8-THP
$288.00Price
  • The formfitting cage incorporates front tabs that prevent the camera from twisting.
    The cage features a variety of 1/4"-20, 3/8"-16, and M4 threaded accessory mounting holes. This allows you to mount accessories without stressing your camera's body.
