The Cage for Sony FX3 with Top Handle Pro combines a formfitting protective cage with an adjustable top handle that offers side-to-side and front-to-back balance adjustments. The cage features numerous 1/4"-20 threaded accessory mounting holes, and it protects your camera from the stress of attaching accessories while leaving you access to your camera's controls and functions.
The Top Handle Pro mounts on top of the cage via an included NATO rail that you attach to your cage. This provides a solid connection between handle and cage and allows you to adjust the balance side to side, as well as slide the handle off when not using it. The top handle grip is a shaft that you can easily slide forward and back as well as remove and reverse from the NATO rail mount. This allows you to adjust the balance of your camera when carrying by the top handle front and back. The top handle grip has cold shoes on top as well as the front, and the back of the grip has an opening for a 15mm rod. The top handle grip is also replete with 1/4"-20 and 3/8"-16 threaded mounting holes.
8Sinn Cage for Sony FX3 + 8Sinn Top Handle Pro
- Formfitting Camera Cage
- 19 x 1/4"-20 Accessory Mounting Threads
- ARRI-Style 3/8"-16 Anti-Twist
- Maintains Access to Camera's Hot Shoe
- Integrated Strap Slots
- Removable ARRI Rosette
- Aluminum Top Handle with ARRI Rosette
- Front Threads for Optional Accessories
8-FX3 C+8-THP Specs
Accessory Mounting Top & Bottom 1/4 “ mounting screws
Top Front M4 threads
1/4" threaded openings
Camera Mounting 1/4"-20 Screw Tripod Mounting Cage: 1/4"-20 Thread, 3/8"-16 Thread
