8SINN HDMI CABLE CLAMP CH2 FOR CAGES
HDMI protective cable clamp has been designed to be attached to the cage. It prevents the cable from being accidentally disconnected. Keeps the HDMI cable in place while protecting the plug and port from being damaged. Carefully designed around the ports compartment. Silver parts of the clamp are movable, which allow adjusting the clamp opening to the size of the cable's plug.
Material: air aluminum
Compatibility: 8Sinn Sony a7III / a7RIII Cage; 8SINN CAGE FOR SONY A7SIII
Dimensions: Height: 29mm, Length: 28mm, Width: 10mm; Weight: 15g
Set includes: 1pc 8Sinn HDMI cable clamp CH2 for Cages
SKU: 8-HDMICC-CH2
$19.00Price
- Two-piece clamp
- 2 screws clamp-to-cage attachment
- Adjustable span
- Aluminum made
