8SINN PANASONIC S1H CAGE + TOP HANDLE SCORPIO
8Sinn Cage with Top Handle Scorpio makes you to comfortably use the Cage for Panasonic DC-S1H for low-angle shots as well as to mount more accessories. The cage features 1/4"-20 mounting threads, a built-in shoe mount, and M4 threads for attaching the 8Sinn Top Handle Extension Adapter, sold separately. The Extension Adapter provides support for the included top handle plus the optional Panasonic XLR audio adapter at the same time. The M4 mounts are positioned on the upper front edge of the cage.
The top handle additionally provides 1/4"-20 and 3/8"-16 threads, a sideways 15mm rod port, and four more shoe mounts, two being in front and two on the rear. Of the four shoe mounts of the top handle, two are positioned facing downwards to allow additional mounting flexibility. The top handle secures to the cage via a thumbscrew rosette mount.
Set includes: 1pc 8Sinn Panasonic S1 / S1R Cage; 1pc 8Sinn Top Handle Scorpio
- 1/4" mounting points
- Cold shoe
- Strap holder
- Ergonomic design
- 3 poinst of cage-to-camera attachment
(bottom screw & pin, eyelet attachment)
- Easy access to plugs, slots, and buttons
- Lightweight
- Aluminum made
Handle:
- 4 x cold shoe mounts
- 360° rotation
- 15mm rod attachmentSupport Type Cage, Handheld Support Grip Type Topside Handgrip Camera Compatibility Panasonic DC-S1H Mounting
Rod Standard 15 mm Single Rod Accessory Mounting Cage, Top: 10 x 1/4"-20 Thread
Cage, Front: 6 x M4 Thread
Cage, Sides: 17 x 1/4"-20 Thread
Cage, Base: 17 x 1/4"-20 Thread, 1 x 3/8"-16 Thread
Top Handle: Multiple x 1/4"-20 Thread, Multiple x 3/8"-16 ThreadCamera Mounting 1/4"-20 Screw Tripod Mounting Cage: 1/4"-20 Thread, 3/8"-16 Thread Rod Ports Top Handle: 1 x 15 mm Rod Port Shoe Mounting Cage, Top: 1 x Cold Shoe
Top Handle: 4 x Cold ShoeRosettes Top Handle, Base: 1 x ARRI Rosette w/ M6 Thread General
Construction Aluminum Dimensions 5.7 x 2.8 x 1" / 14.5 x 7.1 x 2.5 cm
6.1 x 4.2 x 2.7" / 15.5 x 10.6 x 6.8 cmWeight 7.2 oz / 205 g (Cage)
7.7 oz / 218 g (Top Handle)
