The Cage for Panasonic S5 with Top Handle Pro combines a formfitting protective cage with an adjustable top handle that offers side-to-side and front-to-back balance adjustments. The cage features numerous 1/4"-20 threaded accessory mounting holes, and it protects your camera from the stress of attaching accessories while leaving you access to your camera's controls and functions.
The Top Handle Pro mounts on top of the cage via an included NATO rail that you attach to your cage. This provides a solid connection between handle and cage and allows you to adjust the balance side to side, as well as slide the handle off when not using it. The top handle grip is a shaft that you can easily slide forward and back as well as remove and reverse from the NATO rail mount. This allows you to adjust the balance of your camera when carrying by the top handle front and back. The top handle grip has cold shoes on top as well as the front, and the back of the grip has an opening for a 15mm rod. The top handle grip is also replete with 1/4"-20 and 3/8"-16 threaded mounting holes.
8Sinn Panasonic S5 Cage + Top Handle Pro
- Formfitting Camera Cage
- 19 x 1/4"-20 Accessory Mounting Threads
- ARRI-Style 3/8"-16 Anti-Twist
- Maintains Access to Camera's Hot Shoe
- Built-In Strap Slots
- Adjustable Top Handle
- M4 Threads for Optional Accessories
8Sinn Cage For Panasonic S5 Specs
Accessory Mounting Cage, Top: 6 x 1/4"-20 Thread, 1 x Anti-Twist 3/8"-16 Thread
Cage, Sides: 13 x 1/4"-20 Thread
Cage, Front: 6 x M4 ThreadCamera Mounting 1/4"-20 Screw Tripod Mounting Cage: 1/4"-20 Thread, 3/8"-16 Thread Shoe Mounting Cage: 1 x Cold Shoe Rosettes None General
Support Type Cage Grip Type None Camera Compatibility Panasonic DC-S5 Dimensions 5.8 x 4.1 x 2.6" / 147 x 105 x 66 mm Weight 6 oz / 170 g Packaging Info
Package Weight 0.71 lb Box Dimensions (LxWxH) 9.2 x 5.6 x 3.1" 8Sinn Black Raven Top Handle Specs
Grip Type Topside Handle with Cheeseplate-Style Handle Rotation Yes, 360° Built-In Controls None Mounting
Attachment Method Attaches via 1 x Built-In ARRI Anti-Twist 3/8"-16 Screw Accessory Mounting 2 x ARRI Anti-Twist 3/8"-16 Thread
8 x 1/4"-20 ThreadShoe Mounting 1 x Built-In Cold Shoe Slot Rosettes None Rail Mounting None General
Construction Aluminum
