8SINN SONY A7III / A7RIII CAGE + TOP HANDLE PRO
The 8Sinn Cage for Sony a7R III and a7 III is a CNC-machined, anodized aluminum full-armored cage with integrated accessory mounting holes. (HDMI Cable Clamp Not Included). The cage is suitable for use with the Sony a7 III and a7R III, and features a built-in cold shoe. Threaded 1/4"-20, 3/8"-16, and M4 mounting holes allow you to mount accessories without stressing your camera's body.
The cage has two small raised tabs that hold the camera in place and prevent it from twisting. Access to all camera functions, as well as battery and media doors, is maintained.
Set includes: 1pc 8Sinn Sony a7III / a7RIII Cage, 1pc 8Sinn Top Handle Pro
* Full Formfitting Cage
* CNC-Machined Aluminum
* 1/4"-20, 3/8"-16 & M4 Mounting Holes
* Prevents Camera from Twisting
*Optional
- HDMI clamp
- Metaboes Support8Sinn Cage For Sony A7R III And A7 III Specs
Material of Construction Anodized CNC-Machined 6061 Aluminum Mounting Threaded Mounting Holes: 1/4"-20, 3/8"-16, M4
Cold Shoes: 1Dimensions 5.91 x 4.09 x 2.64" / 15.0 x 10.4 x 6.7 cm Weight 7.3 oz / 208 g Packaging Info
Package Weight 0.795 lb Box Dimensions (LxWxH) 9.2 x 5.7 x 3.1" 8Sinn Pro Top Handle Specs
Grip Type Topside Handgrip Mounting
Accessory Mounting Multiple x 1/4"-20 Thread
Multiple x 3/8"-16 ThreadPhysical
Dimensions 5.9 x 2.7 x 2.7" / 14.9 x 6.9 x 6.8 cm Weight 4.2 oz / 120 g
