8SINN SONY A7III / A7RIII CAGE + TOP HANDLE SCORPIO
The 8Sinn Cage and Top Handle Scorpio with 28mm Rosette for Sony a7 III and a7R III is a CNC-machined, anodized aluminum, full-armor cage with integrated accessory mounting holes and adjustable top handle system (HDMI Cable Clamp Not Included). The cage is suitable for use with the Sony a7 III and a7R III, and features a built-in cold shoe. Threaded 1/4"-20, 3/8"-16, and M4 mounting holes allow you to mount accessories without stressing your camera's body.
The top handle attaches via a 28mm rosette system, allowing the top handle to be mounted in multiple orientations and not just forward- or rear-facing. It features four cold shoe mounts and multiple 1/4"-20 and 3/8"-16 threaded mounting holes. The cage has two small raised tabs that hold the camera in place and prevent it from twisting. Access to all camera functions, as well as battery and media doors, is maintained.
Set includes: 1pc 8Sinn Sony a7III / a7RIII Cage, 1pc 8Sinn Top Handle Scorpio
$308.00Price
  • * Full Formfitting Cage
    * CNC-Machined Aluminum
    * 1/4"-20, 3/8"-16 & M4 Mounting Holes
    * Prevents Camera from Twisting
    *Optional
    - HDMI clamp
    - Metaboes Support
    Handle:
    - 4 x cold shoe mounts
    - 360° rotation
    - 15mm rod attachment
    - 1/4" and 3/8" mounting points
  • Material of Construction Anodized CNC-Machined 6061 Aluminum
    Mounting Cage
    Threaded Mounting Holes: 1/4"-20, 3/8"-16, M4
    Top Handle
    Cold Shoes
    Cage: 1
    Top Handle: 4
    Dimensions Cage: 5.91 x 4.09 x 2.64" / 15.00 x 10.40 x 6.70 cm
    Top Handle: 5.71 x 2.8 x 0.98" / 14.5 x 7.1 x 2.5 cm
    Weight Cage: 7.3 oz / 208 g
    Top Handle: 7.7 oz / 218 g
