Outfit your RED KOMODO or V-RAPTOR with this Top Handle Pro and NATO Rail from 8Sinn to expand its mounting capabilities and add an ergonomic grip. Various 1/4"-20, 3/8"-16 threads with ARRI locating points, and two cold shoe mounts allow you to mount articulating arms or monitors onto your rig. The handle attaches via a NATO clamp and can be adjusted to best suit your grip. Aluminum construction ensures a lightweight but durable design.
8Sinn Top Handle Pro with NATO Rail (2.4")
The 8Sinn Pro Top Handle mounts easily on your camera cage using the included 2.4" NATO rail. The NATO rail mount makes it easy to attach and remove the handle and slides to help balance your camera. It features a single 15mm rod bracket, two cold shoe mounts, and multiple 1/4"-20 and 3/8"-16 accessory threads.
8Sinn NATO Rail for RED KOMODO/V-RAPTOR
Mount this NATO Rail from 8Sinn on top of your RED KOMODO or V-RAPTOR to increase the mounting capabilities of your camera and integrate NATO or ARRI compatible accessories. The rail attaches via two safety pins and has four 1/4"-20 threads and one 3/8"-16 ARRI-style thread with locating pins to attach a top handle, articulating arm, or secondary monitor to your setup. Its aluminum construction makes the rail durable and lightweight.
Compatibility
- RED KOMODO
- RED V-RAPTOR
8Sinn Top Handle Pro and NATO Rail for RED KOMODO/V-RAPTOR
- For RED KOMODO and V-RAPTOR
- 1/4"-20 and 3/8"-16 Female Threads
- NATO Rail, Two Cold Shoes
- 15mm Rod Opening
