Outfit your RED V-RAPTOR with this Top Plate and Scorpio Top Handle from 8Sinn to expand its mounting capabilities and add an ergonomic grip. Various 1/4"-20 and 3/8"-16 threads allow you to mount articulating arms or monitors to your rig. An ARRI rosette mount secures the top handle which adds four cold shoe mounts to the setup. Aluminum construction ensures a lightweight but durable design.
8Sinn Top Plate for RED V-RAPTOR
This Top Plate from 8Sinn mounts on your RED V-RAPTOR via four screws either forwards or backwards, depending on the needs of your setup. Multiple 1/4"-20 and 3/8"-16 threads and ARRI locating pins make mounting various accessories, from articulating arms to secondary monitors, a breeze. Because the plate attaches to the camera only by four screws, it retains good air circulation and avoids damaging the RED V-RAPTOR's surface. The aluminum design is lightweight and durable.
8Sinn Scorpio Top Handle
The Scorpio Top Handle from 8Sinn is made of CNC aluminum. The handle features 1/4"-20 and 3/8"-16 mounting holes, four cold shoes, and a 15mm rod mount.
8Sinn ARRI Rosette 28mm Mount
The 8Sinn ARRI Rosette 28mm Mount is a standard-size ARRI rosette mount with an M6 thread in the center for attaching compatible handgrips and other accessories. It can be secured to camera cages and other supports that have two 1/4"-20 mounting threads. It secures with two included 1/4"-20 screws, and it features wide 1/4"-20 pass-through slots so you can set the screws at the required spacing to match the accessory you're attaching to.
8Sinn Top Plate for RED V-Raptor + 8Sinn Top Handle Scorpio
- For RED V-RAPTOR
- 1/4"-20 & 3/8"-16 Female Threads
- ARRI Locating Points, Four Cold Shoes
- 15mm Rod Mount
- ARRI Rosette Mount with Screws
- Aluminum Construction
