8Sinn 8-FX6 TP Overview
Add versatility and additional accessory mounting points to the top of your FX6 camera without disturbing the camera's top handle with the 8SINN Top Plate for Sony FX6. The Top Plate securely mounts on your camera via four points, providing a solid foundation for attaching accessories to the top of your camera. The plate is designed so you can mount it on the camera without removing or interfering with the Sony Top Handle.
Made from aluminum, this lightweight top plate features four 3/8"-16 threaded mounting holes surrounded with ARRI accessory mount anti-twist divots. Additionally, a plethora of 1/4"-20 threaded mounting holes are machined into the top and sides of the plate, providing you with flexibility where you mount your accessories. Two strap slots are machined into the plate as well, for those who wish to use a camera strap.
8Sinn Top Plate for Sony FX6
- Mounts with Top Handle in Place
- 4 x Attachment Points to Camera
- 4 x 3/8"-16 Holes with ARRI-Anti Twist
- Multiple 1/4"-20 Threaded Mounting Holes
- Integrated Strap Slots
8Sinn 8-FX6 TP Specs
Material of Construction Aluminum
Mounting To Camera
4 x Holes
Accessory
Multiple 1/4"-20 Threaded Holes
4 x 3/8"-16 ARRI-Compatible
2 x Strap SlotsDimensions 5.28 x 3.66 x 0.51" / 134 x 93 x 13 mm
Weight 5.36 oz / 152 g
