8Sinn top plate for RED® V-Raptor is a one piece plate designed the way all camera accessories can be attached to it. 1/4" and 3/8” Arri threaded holes cover the entire top plate body, allowing free use of nato rails, handles, monitor holders, etc. The top plate is mounted on the camera’s top with 4 screws. It can be attached facing the front or back of the camera, depending on your preferences. What is important, the top plate itself does not adhere the camera’s body. The only four places where top plates adhere are the places where attachment screws are mounted. Such solution prevents the Red V-Raptor from unwanted damage as well as ensures good air circulation.
8Sinn reversible right side plate dedicated to the RED® V-Raptor camera is a left/right side plate. That is it can be mounted not only on camera’s left but also right side. The plate is attached to the camera by 2 screws. The only two places where the plate adheres the camera’s body is the place where screws are attached. Such solution prevents the camera from unwanted damage by the use of too long screws. 8Sinn RED® V-Raptor plate is equipped with many mounting points: 1/4" as well as 3/8” Arri locating points.
8Sinn Left side plate for RED® V-Raptor camera is an air-aluminum plate that was designed specifically to be mounted on Red V-Raptor camera’s right side. Right side plate is full of various mounting points both 1/4" and 3/8” Arri. It doesn’t cover crucial camera elements like vents. 8Sinn guarantees full access to all camera ports, plugs, inputs, and outputs.
If needed, 3/8" openings can be easily transformed into 1/4" with the use of a reductions screw, also available at the 8Sinn store.
Set includes
1pc 8Sinn Right Side Plate for RED® V-Raptor, 1pc 8Sinn Left Side Plate for RED® V-Raptor, 1pc 8Sinn Top Plate for RED® V-Raptor
8Sinn Top Plate + Right & Left Side Plate For RED V-RAPTOR
- Three-piece set
- 1/4" mounting points
- Arri locating points (+ 3/8" mounting point)
- Aluminum made
