8Sinn ULTIMATE KIT FOR RED KOMODO
The Ultimate Kit for RED KOMODO from 8Sinn provides a comprehensive array of components to support your RED DIGITAL CINEMA KOMODO camera. This kit pairs a dedicated three-sided cage with a removable top plate, a 15mm LWS baseplate, a riser plate, and a 10" ARRI-style dovetail plate. Together, these components provide four-sided protection and multiple accessory mounting options for your RED DIGITAL CINEMA KOMODO camera.
8Sinn Black Raven Top Handle
The Black Raven Top Handle from 8Sinn mounts on your 8Sinn or other-brand cage using a secure ARRI-style anti-twist mount. Handle features include tool-free adjustments, a modern design, and a lightweight yet durable aluminum build.
Multiple accessory mounting options include one cold shoe mount, two ARRI-style anti-twist 3/8"-16 threads, and multiple 1/4"-20 threads.
Compatibility
8Sinn cages with an ARRI-style anti-twist top thread
Other cages with an ARRI-style anti-twist top thread
8Sinn 15mm Baseplate
The 8Sinn 15mm Baseplate is ARRI dovetail compatible and supports optional camera-specific riser plates from 8Sinn. Available plates include the Riser Plate Basic, which supports the URSA Mini, C100, and Sony FX-9 cameras, and the Riser Plate I, which is for select 8Sinn Z CAM, a7/a7R, and Blackmagic Pocket 4K/6K cages. These optional plates set the supported cameras at the appropriate optical center on the 15mm Baseplate.
The 15mm Baseplate features 15mm LWS rod support via front and rear rod ports and a tightening lever on the left and right sides. The left side has a second lever, and this is for securing the compatible riser plate. The 15mm Baseplate offers two ARRI rosette mounts for attaching optional handgrips, and it also provides a section with multiple 1/4"-20 accessory mounting threads. The baseplate is made with excess weight cut out to provide a minimalist, lightweight design.
  • Supports optional camera-specific riser plates from 8Sinn
  • Compatible with the Riser Plate I and Riser Plate Basic
  • ARRI dovetail compatible
  • 15mm LWS rod support
  • ARRI rosette mounts
  • 1/4"-20 accessory mounting threads
8Sinn Riser Plate I
The Riser Plate I from 8Sinn is designed to be used with the 8Sinn 15mm Baseplate and select 8Sinn Z CAM, a7/a7R, and Blackmagic Pocket 4K/6K cages. Please see the compatibility list in the Features section below. The plate sets the cameras of those cages at an 85mm optical center.
The Riser Plate I is made of aluminum and comes with 1/4"-20 and 3/8"-16 screws. Rubber padding provides anti-scratch and anti-twist support for your cage.
Compatible Cages
  • 8Sinn Cage for Z CAM E2-S6/F6/F8
  • 8Sinn Cage for Sony a7R III and a7 III
  • 8Sinn Cage for Sony a7R IV
  • 8Sinn Cage for Blackmagic Pocket Cinema Camera 4K/6K
  • 8Sinn Half Cage for Blackmagic Pocket Cinema Camera 4K/6K
8Sinn 10" ARRI Dovetail Plate
The 8Sinn 10" ARRI Dovetail Plate can be used with 8Sinn's 15mm Baseplate or 3rd-party ARRI dovetail bridge plates to balance large camera setups with large lenses. The plate is designed with cutouts throughout its length so that it can be more lightweight. In this minimalist design made out of a single piece of aluminum, the plate offers reinforced 1/4"-20 and 3/8"-16 threads, a release pin, and a stopper screw.
Note : Rods are not included and must be ordered separately.
8Sinn ULTIMATE KIT for Red Komodo
SKU: 8-REDK-ULT-K
$552.00Price
    • Cage for RED KOMODO + Top Plate
    • Black Raven Top Handle
    • 15mm LWS Baseplate + 10" Dovetail Plate
    • Riser Plate I
