The 8Sinn Cage for FUJIFILM X-T4 and Top Handle Scorpio with 28mm Rosette combines a formfitting protective cage with an aluminum top handle and a removable ARRI rosette that allows you to orient the top handle through 360° forward and back. The removable ARRI-style rosette features 1/4" mounting slots, allowing you to position it at a variety of positions on the cage. The slots are countersunk to match the included screw heads for a snug, nonslip fit. The cage features numerous 1/4"-20 threaded accessory mounting holes, and it protects your camera from the stress of attaching accessories.
The Scorpio's M6 mounting screw threads into the rosette's M6 threaded mounting hole, and the interlocking ridges provide a twist-free lock. The Scorpio's knuckle can be loosened slightly, allowing you to turn the top handle as needed and then quickly lock it back into place. The top handle features multiple 1/4"-20 and 3/8"-16 threaded mounting holes, four cold shoes (two in front and two in the rear), and a 15mm rod clamp well suited for attaching an optional 15mm rod and EVF or another accessory.
8Sinn Fuji X-T4 Cage + Top Handle Scorpio
- Formfitting Camera Cage
- 15 x 1/4"-20 Accessory MountingThreads
- 2 x ARRI-Style 3/8"-16 Anti-Twist
- 2 x ARRI-Style 1/4"-20 Anti-Twist
- Maintains Access to Camera's Hot Shoe
- Built-In Shoe Mount, Strap Slots
- Front Threads for Optional Lens Adapter
- Side Threads for Optional Cable Clamp
8Sinn 8-FXT4 C Specs
Support Type Cage Grip Type None Camera Compatibility FUJIFILM X-T4 Mounting
Battery Plate Type None Accessory Mounting Cage, Top: 8 x 1/4"-20 Thread, 1 x Anti-Twist 3/8"-16 Thread
Cage, Sides: 7 x 1/4"-20 Thread, 2 x Anti-Twist 1/4"-20 Thread, 1 x Anti-Twist 3/8"-16 Thread
Cage, Front: 2 x M4 ThreadCamera Mounting 1/4"-20 Screw Tripod Mounting Cage: 1/4"-20 Thread, 3/8"-16 Thread Shoe Mounting Cage: 1 x Cold Shoe Rosettes None General
Dimensions 5.9 x 4.1 x 2" / 15 x 10.5 x 5 cm Weight 5.7 oz / 163 g
