The ML-ALL LIGHT Light Module from Matrix Light features:
ALL LIGHT, Ultimate Light Source
Matrix Light ALL LIGHT 1, 2, and 4 are designed and built with the goal of creating the ultimate lighting that professionals have wanted. The product reflects the diverse needs of the field and creates a fast and seamless user experience that enables professional users to deploy light sources as closely as possible to the real world. Professional users can easily meet their needs by using the ALL LIGHT Series when they need multi-functional, high-performance lighting to suit their situations, such as broadcasting, movies, commercials, and live events.
Innovative Graphic Touch Interface
The Matrix Light ALL LIGHT Series features an innovative Graphic Touch control interface, which provides users with quick and easy access to a variety of menus, making it incredibly easy and convenient to control compared to the complex and cumbersome operating methods adopted by similar products.
Wire /Wireless Control Interface
The Matrix Light ALL LIGHT Series complies with the DMX-512 standard protocol to make it fully compatible with traditional lighting controllers. The ALL LIGHT Series can also be controlled with smartphones and tablets via Bluetooth connection.
Preset / Preset Save
The Matrix Light ALL LIGHT Series has a preset menu that recreates the colors of many different light sources. In addition, the colors and brightness of the various light sources you set are saved through the Preset Save menu, and the saved settings can be recalled and used at any time. These features make it very convenient to match the settings of the same lighting when shooting multiple scenes in succession on the scene.
Multi Effect and Color Filter
The ALL LIGHT provides users a wide range of preset lighting effects. Users can also easily create their custom lighting effects by using the ALL LIGHT effect creator. The ALL LIGHT includes hundreds of color filters, which can be accessed by their code value or name. The color filters not only simplify the color lighting process, but also enable precise and flexible color control.
Stronger body, Better performance
The ALL LIGHT's main body includes a high-efficiency aluminium heat sink and a cooling fan. This feature help minimize the effect of temperature difference on the ALL LIGHT's performance. In addition, the mechanical strength and lifespan of the product's key parts and accessories have been significantly improved. ALL LIGHT will be the most ultimate form of LED light, providing the highest quality of light as intended by the photographer.
The Matrix Lights All Light 1, 2 4 series is the most advanced LED Light. Convenient and intuitive interface, various effects, hundreds of color filters, wired/wireless control systems, those are enough conditions for the All Light 1, 2, 4 series to be the ultimate light source.
Matrix Light ALL Light 4
$5,199.00 Regular Price
$4,159.20Sale Price
  • Matrix Light ML-AL1 Specs
    Type Current-regulated power LED light
    Projection Effective Light Projection Range: 0.6 to 6 m (depends on shutter speed, aperture levels, and gain control)
    Projection Angle Light Projection Angle
    Horizontal: 110°
    Vertical: 90°
    Color Temperature 3200K to 5800K (240K / step)
    Brightness 10 to 100% (230 lumens / step)
    Maximum Brightness Maximum 1100 lumens (Normal mode)
    Maximum 2200 lumens (Turbo mode)
    Luminance Maximum 1100 lux at 3.3' (Normal mode)
    Maximum 2200 lux at 3.3' (Turbo mode)
    Power Supply 12 VDC
    Current Consumption Normal Mode: 1.5 A / 18 W (maximum)
    Turbo Mode: 3 A / 36 W (maximum)
    Luminance Efficiency: 66 lumens / W
    Brightness Control 150 to 2200 lumens in 240-lumen increments
    Color Temperature 3200K to 5800K in 240K increments
    Battery Power 12 VDC / 5200 mA (Li‐ion)
    Battery Life 2 hours 30 minutes (Maximum brightness in Normal mode)
    1 hour 15 minutes (Maximum brightness in Turbo mode)
    Dimensions 3.07 x 4.45 x 0.12" / 78 x 113 x 30 mm
    Weight 8.9 oz / 251 g
    Package Weight 0.85 lb
    Box Dimensions (LxWxH) 7.1 x 5.5 x 3.4"
    • Matrix Light ML-AL4 Light Module
    • Limited 1-Year Warranty
