A compact device with many functions, the DIGITAL FORECAST Bridge X_TS V3 Trouble Shooter can be a signal converter, format converter, and a test-pattern generator. SDI, HDMI, VGA, component, and composite video formats are supported on input and output. Any input can be converted to any available output, and all outputs are simultaneously active. Analog stereo and AES/EBU audio embedding is supported. The front of the Bridge X_TS features a touchscreen LCD for monitoring incoming and outgoing video signals, audio levels, SDI metrics, and more. Power can be supplied using the included power adapter, or with optional Sony batteries using the included battery plate. Accessory adapter cables for Component to VGA video and RCA to 3.5mm audio are also included, as is a hard case for storage and transport when not in use.
DIGITAL FORECAST Bridge X_TS V3 Trouble Shooter Basic Kit
SKU: X_TS V3
$1,139.05Price
  • *Up/Down/Cross/Scan converter
    *Analog to Digital/ Digital to Analog converter
    *SDI, HDMI, VGA, Component, Composite, AES/EBU, and analog audio support
    *Analog audio embedding/de-embedding
    *User-selectable output format
    *Test pattern generator
    *Eye Pattern / Jitter on HD-SDI signal
    *OSD menus
    *Audio level monitoring (up to 8-channels)
    *5" touchscreen LCD
    *Portable battery plate can be attached for portable power solution (Sony L- Type and Canon LP-E6)
