Fomex RollLite is an LED lighting system that gives you a whole new level of experience that you have never felt before. Fomex RollLite precisely emphasizes the subject's true color with a high light intensity, and is lightweight, and easy to move and install, perfectly meets the demanding requirements of professional lighting.
Separately and Together, Easy and Various Installation
Fomex RollLite is an innovative LED Lighting System that can be transformed freely depending on the location and circumstances. Mats can be combined to expand to the desired size as needed. Fomex RollLite uses an integral snap-grommet to allow quick and easy installation on the Butterfly, X-mounts for stand, ceilings or more.
Perfect and Delicate Color
Fomex RollLite is precise LED lighting to express white color that is perfect under any circumstances. Fomex RollLite maximizes color  flexibility, allowing you to choose a color temperature from 2700K to 6500K and ensures TLCI98 and CRI96 to achieve the most exact color with your intent to look at the subject.
Protected
The RollLite is made of a unique antibacterial textile, with IP64 protection against dust and water splashes from any direction
Connector
The connector can be set to operate horizontally or vertically (90 degree adjustment)
X-Mount
The included X-Mount frame can be quickly and easily mounted to the RollLite using the push-pin one-touch locking inserts
Specification
  • Light Output : 3100lux @1m; 2700K, 3500lux @1m; 6500K
  • Power Consumption : 150W
  • CRI / TLCI : CRI 96~98 / TLCI 98
  • Color Temperature : 2700K~6500K
  • Dimmer : 0~100% DIM / DMX 512 / Manual
  • Color Temp. Control : 100K Steps
  • Output Connector ( Waterproof ) : 6Pin × 1
  • Mat IP Rating : IP64
  • Input : 12-24V DC (4Pin)
  • DC Out : 5V DC Out ( USB for WDMX )
  • DMX In / Out : 5Pin XLR
  • Beam Angle : 120°
  • LEDs : 684
  • Battery Mounts : V-Mount / Gold Mount
  • Mat Dimensions (ft) : 4' x 1' (120 x 35cm)
  • Mat Weight (g) : 800
Fomex RollLite RL41-150 Kit
SKU: RL41 - 150 Kit
$2,836.00Price
    • RollLite LED Mat 4'x1' (1200x350mm)
    • Controller for RL21/31/41
    • Power Supply for RL21/31/41/EX1800
    • Output cable(6-pin) 2m for Controller
    • Extension cable(6-pin) 5m
    • X-mount Ass'y for RL41
    • Super Clamp Adaptor Shoe w/Spigot
    • Kit Bag for RL21/31/41
