Run your V-mount camera or pro video accessory on the G-B100 14.4V, 195Wh Li-Ion Battery from GEN ENERGY. Offering 14.4V power via its V-mount connection, this robust battery has a capacity of 13.5Ah and supports high-current draws up to 15A. Two integrated D-Tap ports allow you to run accessories directly from the battery, and a USB interface allows you to charge your smartphone and other electronic devices while shooting.
  • Five-LED gauge displays remaining power
  • Two D-Tap ports and one USB port for powering/charging accessories
GEN ENERGY 15A / 195Wh Li-Ion Battery (V-Mount)
SKU: G-B100/195W15A
$459.00Price
    • 14.4V 195Wh Li-Ion V-Mount Battery
    • Supports up to 15A Total Draw
    • World-only US Military Drop-Test Certified
    • World-only Shockproof Wireless Design
    • World-only Cableless PCB design
    • 2 x D-Tap Accessory Outputs
    • 1 x USB Port
    • 10-LED Power Gauge
    • Compact Vertical Design
