Run your V-mount camera or pro video accessory on the G-B100 14.4V, 290Wh Li-Ion Battery from GEN ENERGY. Offering 14.4V power via its V-mount connection, this robust battery has a capacity of 20Ah and supports high-current draws up to 22A. Two integrated D-Tap ports allow you to run accessories directly from the battery, and a USB interface allows you to charge your smartphone and other electronic devices while shooting.
- Five-LED gauge displays remaining power
- Two D-Tap ports and one USB port for powering/charging accessories
GEN ENERGY 22A / 290Wh Li-Ion Battery (V-Mount )
SKU: G-B100/290W22A
$799.00Price
- 14.4V 290Wh Li-Ion V-Mount Battery
- Supports up to 22A Total Draw
- World-only US Military Drop-Test Certified
- World-only Shockproof Wireless Design
- World-only Cableless PCB design
- 2 x D-Tap Accessory Outputs
- 1 x USB Port
- 10-LED Power Gauge
- Compact Vertical Design
