The ML-SG4K LED Sun Gun Light Module from Matrix Light is a portable spot light with a maximum brightness of 4750 lumens and a water-resistant design. The separately available ML-BA40W lithium-ion battery allows the module to run for more than two hours.
  • Aluminum body
  • Micom controller for precise light control
  • Brightness adjustments in 10% increments to 4750 lumens
All round Play LED Sun Gun Light
Matrix Light’s ML-SG4K LED Sun Gun Light is a Portable Spot Light that will perfectly support any news gathering situation. With a maximum brightness of 4,750lm, reliable waterproofing, and excellent portability, the ML-SG4K LED Sun Gun Light is the superior choice. The ML-SG4K LED Sun Gun Light is an all-round light system, meaning it’s not only for news gathering but also for any shooting situation. As such it possesses none of the halogen lamp’s weaknesses such as low luminance efficiency and short battery life. The ML-BA40W Lithium-ion Battery provided with the SG4K LED Sun Gun Light, is the waterproof and high-efficient power source that allows the ML-SG4K LED Sun Gun Light to run for more than two hours in any weather conditions.
Solid Body & Precise Micom Control
ML-SG4K LED Light’s aluminum body is lightweight yet durable, and acts as an excellent heat sink, maximizing durability and lifetime. Also, the sophisticated micom controller promises the ML-SG4K LED Light to be the most advanced LED light providing users with precise light control and the best quality.
Electronic Dimming Control and Convenient Design
The Dimming controller located on the ML-SG4K LED Sun Gun Light’s handle allows users to achieve the perfect brightness in 10% increments to 4,750lm. Also the handle is detachable from the light body, maximizing its convenience.
10 STEPS Dimming Control
▪ Type :  Current regulated power LED light
▪  Light projection range : 0.6 ~ 10M (Effective light projection range)
              (depends on shutter speed, aperture levels, and gain control)
▪  Light projection angle Horizontal: 60 ˚ vertical: 60 ˚
▪  Color Temperature: 4,000K
▪  Brightness: 10% ~ 100% (Digital variable)
▪  Luminance Flux:  4,750lm MAX
▪  Illuminance in 1M distance:  4,000lux MAX
▪  Power supply: 48V DC
▪  Current consumption: 1A/48W(Max)
▪  Luminance efficiency: 96lm/W
▪  Battery: 48V DC / 2,600mA (Li‐ion)
▪  Battery running time: 2hrs. (With Maximum Brightness)
Matrix Light ML-SG4K Basic Kit
$2,570.00 Regular Price
$2,184.50Sale Price
  • Light Fixture
    Type Current-regulated power LED light
    Projection Effective Light Projection Range: 0.6 to 10 m (depends on shutter speed, aperture levels, and gain control)
    Projection Light Projection Angle
    Horizontal: 60°
    Vertical: 60°
    Color Temperature 4000K
    Brightness 10 to 100% (digital variable)
    Maximum Brightness Maximum 4750 lumens
    Luminance Maximum 4000 lux at 3.3'
    Power Supply 48 VDC
    Current Consumption 1 A / 48 W (maximum)
    Luminance Efficiency: 96 lumens / W
    IP Rating IP64
    Dimensions 11 x 3.7 x 4.9" / 280 x 95 x 125 mm
    Weight 1.57 lb / 710 g
    Battery
    Battery Model Supported ML-BA48W
    Battery Power 48 V, 125 W / 2600 mA (Li‐ion)
    Battery Life 2 hours with maximum brightness
    Dimensions 7.9 x 2.6 x 2.6" / 200 x 67 x 67 mm
    Weight 2.2 lb / 1 kg
