The Storm 3000 from Vaxis features a 3000' range and supports up to 1080p60 uncompressed signal transmission with less than 1 ms of latency over the 5.1 to 5.9 GHz frequency. The transmitter features 3G-SDI and HDMI inputs plus a 3G-SDI loop output, and the receiver has dual 3G-SDI simultaneous outputs and an HDMI output. Both units come with Gold mount battery plates. Both also support continuous power via 2-pin LEMO power inputs. Two D-Tap to LEMO cables are included.
Other features include OLED displays, multicasting, timecode and metadata support, ARRI ALEXA Mini instant playback, and smart active cooling that allows for extended operation in hot environments. Both units are designed with a robust metal housing.
Key Features
- Up to 1080p60 uncompressed transmission
- 3000' range with less than 1 ms of latency over 5.1-5.9 GHz frequency
- User-configurable frequency bands
- Transmitter: SDI input, HDMI input, SDI loop output; Gold mount battery plate
- Receiver: 2 x SDI outputs, HDMI output; Gold mount battery plate
- 2-pin LEMO power inputs
- WHDI (MIMO/OFDM) technology
- ARRI ALEXA Mini instant playback
- Smart active cooling, allowing extended operation time in hot environments
- OLED screens
- Timecode and metadata support
- Multicasting
- All-metal housing
- Less than 63mW radio power
- 1/4"-20 mounting thread on the bottom of each unit
Vaxis Storm 3000 Kit (Gold Mount)
- Vaxis Storm 3000 3G-SDI & HDMI Wireless Transmission Kit
- Transmitter with V-Mount Plate
- Receiver with V-Mount Plate
- 7 x Sword Antenna
- 2 x D-Tap to 2-Pin LEMO Cable
- Articulating Arm (7")
- Flight Case
- Limited 1-Year Warranty
Vaxis Storm 3000 Specs
Wireless
Wireless Range 3000' / 914.4 m (Line-of-Sight) Channel Bandwidth 40 MHz Frequency Range 5.1 to 5.9 GHz Latency < 1 ms Wireless Video Compression Uncompressed Interfaces
Transmitter Antenna Ports 2 x RP-SMA Receiver Antenna Ports 5 x RP-SMA Transmitter Video Connectors 1 x BNC (3G-SDI / HD-SDI / SD-SDI) Input
1 x HDMI Input
1 x BNC (3G-SDI / HD-SDI / SD-SDI) Loop OutputReceiver Video Connectors 2 x BNC (3G-SDI / HD-SDI / SD-SDI) Output
1 x HDMI OutputFormat Support
Video Format SDI/BNC:
1080p at 23.98, 24, 30, 50, 59.94, 60 fps
1080i at 50, 59.94, 60 fps
1080PsF at 23.98, 24, 25, 29.97, 30 fps
720p at 50, 59.94, 60 fps
576p at 60 fps
HDMI:
1080p at 23.98, 24, 50, 59.94, 60 fps
576p at 60 fpsTimecode Yes Display
Transmitter Panel Type OLED Receiver Panel Type OLED Power
Transmitter Battery Support 1 x V-Mount Receiver Battery Support 1 x V-Mount Transmitter Power Connector 1 x 2-Pin LEMO (6 to 36 VDC) Input Receiver Power Connector 1 x 2-Pin LEMO (6 to 36 VDC) Input Environmental
Operating Temperature 32 to 104°F / 0 to 40°C General
Transmitter Mounting 1 x 1/4"-20 Female Receiver Mounting 1 x 1/4"-20 Female Materials Metal Transmitter Dimensions 4.45 x 2.76 x 1.06" / 11.3 x 7 x 2.7 cm Receiver Dimensions 4.92 x 3.7 x 1.57" / 12.5 x 9.4 x 4 cm Transmitter Weight 0.6 lb / 268 g Receiver Weight 0.9 lb / 405 g Packaging Info
Package Weight 8.275 lb Box Dimensions (LxWxH) 13.4 x 11.95 x 6.1"
