With the Storm 3000' DV Wireless Video Transmitter from Vaxis you can transmit visually lossless, uncompressed video signals to any Vaxis Storm receiver with zero latency. The unit features a dual V-mount plate which allows you to attach it to the V-mount plate on your camera and mount a V-mount battery on the other side, providing pass-through power to both the transmitter and the camera simultaneously. The transmitter features one HDMI input, one SDI input, and one SDI loop output, and it supports input up to 4K and up to 1080p60 video transmissions. The unit also supports cross conversion from HDMI input to SDI loop output.
The transmitter unit can be secured to a camera or other SDI/HDMI video source via a built-in 1/4"-20 threaded hole. The included short antennas provide connectivity for short distances of a few hundred feet, while the larger blade antennas transmit a powerful line-of-sight signal up to 3000'. It also supports the transmission of timecode, metadata, and timecode trigger information.
The Storm 3000 transmitter features 20 selectable 40 MHz channels and a 5.1 to 5.9 GHz wireless frequency range, and on the side is a bright LED display showing your connection status and channel information. The unit can be powered using its 2-pin LEMO port using a D-Tap or AC source with a separately available cable. A standard BNC cable is included so you can plug in right out of the box.
Transmitter unit sends up to 1080p wireless video up to 3000'
One SDI and one HDMI input; one SDI loop output
Compatible with all Vaxis Storm receivers
Dual V-mount pass-through battery plate allows you to power the transmitter and your V-mount camera or device at the same time
HDMI/SDI cross conversion support
Metadata, timecode, and timecode trigger support
Bright LCD screen for settings, status, and scanning for open frequencies on 5.1 to 5.9 GHz range
Mount on rig using 1/4"-20 thread
Vaxis Storm 3000 DV TX Only (Dual V-Mount)
SKU: VS19-3000DV-T01
$3,480.00Price
    • Vaxis Storm 3000' DV Wireless Video Transmitter with Dual V-Mount Plate
    • 2 x Blade Antenna (5 dBi)
    • 2 x Short Antenna (2 dBi)
    • SDI Cable
  • Vaxis Storm 3000 DV Specs
    Wireless
    Wireless Range 3000' / 914.4 m (Line-of-Sight)
    # of Channels 20 (40 MHz)
    Channel Bandwidth 40 MHz
    Frequency Range US: 5.1 to 5.9 GHz
    Latency < 1 ms
    Wireless Video Compression Uncompressed
    Interfaces
    Antenna Ports 2 x RP-SMA Female
    Video Connectors 1 x BNC (3G-SDI) Input
    1 x HDMI (HDMI 1.4) Input
    1 x BNC (3G-SDI) Loop Output
    Other I/O 1 x USB (Unspecified Type) USB 2.0 Input
    Format Support
    Broadcast System Compatibility NTSC, PAL
    Video Format SDI/BNC:
    1080p at 23.98, 24, 50, 59.94, 60 fps
    1080PsF at 23.98, 24, 25, 29.97, 30 fps
    1080i at 50, 59.94, 60 fps
    720p at 50, 59.94, 60 fps
    576p at 60 fps
    HDMI:
    576p at 60 fps
    Timecode Yes
    Display
    Panel Type LCD
    Power
    Built-In Battery None
    Battery Support 1 x V-Mount
    Power Connector 1 x 2-Pin LEMO (6 to 36 VDC) Input
    Environmental
    Operating Temperature 32 to 104°F / 0 to 40°C
    Mounting 1 x 1/4"-20 Female
    Dimensions 4.65 x 3.54 x 1.02" / 118 x 90 x 26 mm
    Weight 10.44 oz / 296 g
GET IN TOUCH
Sales & Product Inquiries*
Email us: info@kameratools.com
*Please note we currently sell to business customers only
View full contact information
  • White Facebook Icon
  • White Instagram Icon
  • YouTube
  • White Pinterest Icon
REPS & PRODUCT INQUIRES
EXPERIENCE
JOIN OUR NEWSLETTER
Copyright © 2020 KameraTools, Inc. Designed by Shot by Ryu
0
