UHD M_DA - Overview
The Digital Forecast Bridge UHD M_DA is a device that distributes SDI signals to SMPTE standards. The supported format is from 480i to UHD and a Re-clocker and equalizer are built-in enabling the UHD-M-DA to also be used as a repeater.
Specifications:
Physical:
Dimension (W x H x D): 80 x 59.4 x 22.5 (mm)
Weight: 95g
Power Level: 7V ~ 16 VDC
Power Consumption: 2.6 Watts (Max: 3 Watts)
Operating Temperature: 0°C ~ 55°C
Humidity: 0 to 95% RH, non-condensing
Data Rate: Max 600Mhz
Signal Level: 800mVp-p +/- 50m Digital Video Specs:
SMPTE-296M : 720P (60/59.94/50)
SMPTE-274M, SMPTE-292M : 1080i (60/59.94/50)
MPTE-424M : 1080p (60/59.94/50) 3G
SMPTE-ST2081 : 2160p (30/29.97/25) 6G
SMPTE-ST2082 : 2160p (60/59.94/50) 12G
Warranty:
2 Year Warranty
