8Sinn 8-ANR28MMM+8-SNR60MM Overview
The ARRI NATO Rosette 28mm Mount + Safety NATO Rail 2.4" Bundle from 8Sinn provides a quick release solution for attaching rosette mount top handles and other accessories to your camera cage or rig. The bundle features a short-length NATO-standard rail and a NATO-mount ARRI-standard rosette adapter with an M6 thread.
8Sinn ARRI NATO Rosette 28mm Mount
Mounting adapter for Arri standard accessories like holders, top handles, etc. This product is a part of the quick-release system when mounted on separate or built-in Safety NATO Rail
8Sinn Safety NATO Rail (2.4")
The 8Sinn 2.4" Safety NATO Rail is a short-length NATO-standard rail that can be attached to camera cages and other camera supports. It attaches using two included 1/4"-20 screws, and it features a slotted design so that you can space out the screws as needed to match the spacing on your cage or other support. The NATO rail provides a quick release mounting solution with a safety pin for NATO-compatible top handles, monitor mounts, and other gear.
8Sinn ARRI NATO Rosette 28mm Mount + Safety NATO Rail 2.4" Bundle
- Quick Release NATO Rail with Safety Pin
- NATO Rail Mount Rosette with M6 Thread
- 1/4"-20 Attachment to Cages & Other Gear
- Supports NATO-Mount Top Handles & More
8Sinn ARRI NATO Rosette 28mm Mount Specs
Package Weight 0.06 lb
Box Dimensions (LxWxH) 2.7 x 2.05 x 1"
8Sinn Safety NATO Rail (2.4") Specs
Material Aluminum
Dimensions 2.4 x 0.35 x 0.8" / 60 x 9 x 20 mm
Weight 0.8 oz / 23 g
Package Weight 0.075 lb
Box Dimensions (LxWxH) 3.8 x 2.65 x 0.65"
