8SINN CAGE FOR RED® KOMODO + 2PCS 8SINN BLACK RAVEN TOP
8Sinn Cage for the RED® KOMODO™ is an open cage, with no top and rear edges. The Top Plate can be added separately when needed. 8Sinn cage is a combination of functionalities and modern design embedded into a solid but lightweight aluminum base. Both sides are equipped with Arri Locating points which guarantee solid accessories attachment. Besides that, there are 1/4" mounting points on both sides. The bottom of the cage has 1/4" threads and relief holes to lessen the weight. The cage is attached to the Komodo camera at 12 points - bottom 1/4" and 3/8" plus 2x M4 and 3xM2.5 threads on each side.
The 8Sinn Black RAVEN Top Handles are attached to both Left & Right Side Plates to allow easy handheld shooting. Each Handle has a built-in Arri standard locating pins with the 3/8" mounting screw in the middle. It guarantees safe and steady handle-to-cage attachment plus adjustment. Besides that, the users can find the usual 1/4" threads on top and the cold shoe mount at the front-top.
Set includes
1pc 8Sinn Cage for Red Komodo; 2pcs 8Sinn Raven Top Handle
8sinn Cage for Red Komodo + 2pcs 8Sinn Black Raven Top Handle
- Cage key features
- solid cage-to-camera attachment
- Arri locating points (+ 3/8" mounting point)
- 1/4" mounting points
- 3-piece cage
- Aluminum made
- Handle key features
- 2 x Arri locating points
- 1 x cold shoe mount
- Attachment: 3/8" thread + Arri locating pins
- No-tools adjustment
- Cage key features
