8SINN CAGE FOR RED KOMODO + TOP PLATE + TOP HANDLE PRO
8Sinn Cage for the RED® KOMODO™ is an open cage, with no top and rear edges. The Top Plate can be added separately when needed. 8Sinn cage is a combination of functionalities and modern design embedded into a solid but lightweight aluminum base. Both sides are equipped with Arri Locating points which guarantee solid accessories attachment. Besides that, there are 1/4" mounting points on both sides. The bottom of the cage has 1/4" threads and relief holes to lessen the weight. The cage is attached to the Komodo camera at 12 points - bottom 1/4" and 3/8" plus 2x M4 and 3xM2.5 threads on each side.
8Sinn Top Plate for the RED® KOMODO™ is an autonomic part. It can be used together with the 8Sinn cage or it can be used alone. It's equipped with three different kinds of threads - all standard for camera accessories. It has been designed to perfectly fit the camera body and not disturb any part of it. 8Sinn Top Plate is not compatible with the RF-PL Mount- KipperTie Revolva, as the plate`s front extends beyond the top edge of the camera. 8Sinn 95mm Safety NATO Rail can take over the role of the top plate. (95mm rail is to be found in the "related products" section below)
8Sinn Top Handle Pro is an aluminum-made camera handle. Having it attached to your camera gives you a safe way of grabbing your setup and, what's more important, provides various mounting points and adjusting possibilities. The handle is equipped with the quick-release system, which grants quick shifting and detaching it from the cage. This handle can be mounted on every surface equipped with at least 2 x 1/4" threaded mounting points or on a built-in Safety NATO Rail.
Set includes
1pc 8Sinn Cage for Red Komodo; 1pc 8Sinn Top Plate for Red Komodo; 8Sinn Top Handle Pro; 1pc 8Sinn Safety NATO Rail 60mm
[*B-STOCK] 8Sinn Cage for Red Komodo + Top Plate + Top Handle Pro
SKU: 8-RK C+8-RK TP+THP
$242.90 Regular Price
$145.74Sale Price
    • Cage key features:
      - 6 points of cage-to-camera attachment
      - 6 x Arri locating points (+ 3/8" mounting point)
      - 1/4" mounting points
      - 3-piece cage
    • Top Plate key features:
      - Arri locating points (+ 3/8" mounting point)
      - 8 x 1/4" mounting threads
      - 4 x M4 mounting threads
      - 2 points of plate-to-camera attachment
    • Handle key features:
      - Quick-release system
      - Front/back, left/right adjustment
      - 1/4" & 3/8" mounting points
      - 1x 3/8" mounting point with Arri locating points
      - 2x cold shoe mounts
      - NATO standard mounting
