8SINN CAGE FOR RED KOMODO + TOP PLATE + TOP HANDLE SCORPIO (INCLUDE 8-AR28MMM)
8Sinn Cage for the RED® KOMODO™ is an open cage, with no top and rear edges. The Top Plate can be added separately when needed. 8Sinn cage is a combination of functionalities and modern design embedded into a solid but lightweight aluminum base. Both sides are equipped with Arri Locating points which guarantee solid accessories attachment. Besides that, there are 1/4" mounting points on both sides. The bottom of the cage has 1/4" threads and relief holes to lessen the weight. The cage is attached to the Komodo camera at 12 points - bottom 1/4" and 3/8" plus 2x M4 and 3xM2.5 threads on each side.
8Sinn Top Plate for the RED® KOMODO™ is an autonomic part. It can be used together with the 8Sinn cage or it can be used alone. It's equipped with three different kinds of threads - all standard for camera accessories. It has been designed to perfectly fit the camera body and not disturb any part of it. 8Sinn Top Plate is not compatible with the RF-PL Mount- KipperTie Revolva, as the plate`s front extends beyond the top edge of the camera. 8Sinn 95mm Safety NATO Rail can take over the role of the top plate. (95mm rail is to be found in the "related products" section below)
8Sinn Top Handle Scorpio is aluminum made and it will stand the test of time. In this matter, the range of camera accessories that can be attached to it, is enormous. Furthermore, 8Sinn has redesigned the main mounting bracket to fit the 8Sinn Arri Rosette, 8Sinn Arri NATO Rosette, as well as the third-party products. No matter which mounting option you choose, the 8Sinn Top Handle Scorpio is the perfect handle choice for your production. What's more, the following handle is equipped with cold shoe mounts and a rod opening to allow you to expand even more.
Set includes
1pc 8Sinn Cage for Red Komodo; 1pc 8Sinn Top Plate for Red Komodo; 1pc 8Sinn Top Handle Scorpio; 1pc Arri Rosette Mount; (mounting screws included)
[*B-STOCK] 8Sinn Cage for Red Komodo + Top Plate + Top Handle Scorpio
SKU: 8-RK C+8-RK TP+THSV2
$242.00 Regular Price
$145.20Sale Price
    • Cage key features:
      - 6 points of cage-to-camera attachment
      - 6 x Arri locating points (+ 3/8" mounting point)
      - 1/4" mounting points
      - 3-piece cage
    • Top Plate key features:
      - Arri locating points (+ 3/8" mounting point)
      - 8 x 1/4" mounting threads
      - 4 x M4 mounting threads
      - 2 points of plate-to-camera attachment
    • Handle key features:
      - 360-degree rotation
      - M6 mounting screw
      - 4 cold shoes
      - 1/4" and 3/8" mounting points
      - 15mm rod mount
