8Sinn 8-FX3 C Overview
Protecting your camera from the rigors of production while providing multiple accessory mounting points is the purpose of the 8Sinn Cage for Sony FX3/FX30. Your camera mounts onto this formfitting cage with a 1/4"-20 slot and is secured both at the baseplate and with a screw on the side. The cage allows access to the camera's controls and hot shoe, and the base features a multitude of 1/4"-20 mounting holes as well as a single 3/8"-16 for attaching to a tripod.
Multiple 1/4"-20 threaded holes distributed along the sides and top of the cage, and it also sports two 3/8"-16 threaded holes with ARRI-style anti-twist divots on its top as well as a single 3/8"-16 threaded hole with ARRI-style anti-twist divots on the left side. Strap slots allow you to attach a camera strap if you wish, and threaded mounting holes in front of the cage enable mounting optional lens adapters. The cage is compatible with the FX3 original XLR handle.
- Formfitting Camera Cage
- 28 x 1/4"-20 Accessory Mounting Threads
- ARRI-Style 3/8"-16 Anti-Twist
- Maintains Access to Camera's Hot Shoe
- Built-In Strap Slots
- Front Threads for Optional Lens Adapter
8Sinn 8-FX3 C Specs
Support Type Cage
Grip Type None
Camera Compatibility Sony FX3, Sony FX30
Battery Plate Type None
Accessory Mounting Cage, Top: 12 x 1/4"-20 Female Thread, 2 x ARRI Anti-Twist 3/8"-16 Female Thread
Cage, Sides: 16 x 1/4"-20 Female Thread, 1 x ARRI Anti-Twist 3/8"-16 Female ThreadCamera Mounting 1/4"-20 Male Screw
Tripod Mounting Cage: 1/4"-20 Female Thread, 3/8"-16 Female Thread
Shoe Mounting None
Rosettes None
Materials Aluminum
Dimensions 5.8 x 3.7 x 2.4" / 147 x 94 x 62 mm
Weight 7.8 oz / 220 g
