This 8Sinn Full Camera Cage and Top Handle Scorpio bundles a camera cage designed for the Leica SL2 and SL2-S, as well as a cheese plate-style top handle for additional mounting and protection. Multiple mounting threads, cold shoe mounts, and even a single 15mm rod port offer compatibility with a variety of accessories.
8Sinn Full Camera Cage for Leica SL2 and SL2-S
Custom-Fit for the Leica SL2 and SL2-S, this Full Camera Cage from 8Sinn protects your camera while offering expanded mounting options. Multiple 1/4"-20 threads, M4 threads, and 3/8"-16 threads with ARRI locating pins offer mounting points for articulating arms, cables, or cable clamps while maintaining access to the camera's ports and buttons. A cold shoe mount at the top of the cage can accommodate a wireless transmitter or microphone. Two strap holders allow you to thread a camera strap through either side for additional security. The cage's aluminum construction ensures it remains durable while being lightweight.
8Sinn Scorpio Top Handle
The Scorpio Top Handle from 8Sinn is made of CNC aluminum. The handle features 1/4"-20 and 3/8"-16 mounting holes, four cold shoes, and a 15mm rod mount.
8Sinn ARRI Rosette 28mm Mount
The 8Sinn ARRI Rosette 28mm Mount is a standard-size ARRI rosette mount with an M6 thread in the center for attaching compatible handgrips and other accessories. It can be secured to camera cages and other supports that have two 1/4"-20 mounting threads. It secures with two included 1/4"-20 screws, and it features wide 1/4"-20 pass-through slots so you can set the screws at the required spacing to match the accessory you're attaching to.
[*B-STOCK] 8Sinn Camera Cage and Top Handle Scorpio for Leica SL2 and SL2-S
- Camera Cage for Leica SL2 and SL2-S
- Maintains Access to Ports and Buttons
- Multiple 1/4"-20, 3/8"-16, M4 Threads
- Five Cold Shoe Mounts
- 15mm Rod Port
- Top Handle Attaches via ARRI Mount
- Handle Rotates 360°
- Aluminum Construction
