Set of two products for equipping both sides of the V-Raptor camera. 8Sinn reversible side plate dedicated to the RED® V-Raptor camera is a left/right side plate. That is it can be mounted not only on the camera’s right but also left side. The plate is attached to the camera by 2 screws. The only two places where the plate adheres the camera’s body is the place where screws are attached. Such solution prevents the camera from unwanted damage by the use of too long screws. 8Sinn RED® V-Raptor plate is equipped with many mounting points: 1/4" as well as 3/8” Arri locating points.
8Sinn Left side plate for RED® V-Raptor camera is an air-aluminum plate that was designed specifically to be mounted on Red V-Raptor camera’s left side. Left side plate is full of mounting points both 1/4" and 3/8” Arri. If needed, 3/8" openings can be easily transformed into 1/4" with the use of a reductions screw, also available at the 8Sinn store. It doesn’t cover crucial camera elements like vents. 8Sinn Left Side Plate guarantees full access to all camera ports, plugs, inputs and outputs.
Set includes
1pc 8Sinn Right Side Plate for RED® V-Raptor, 1pc 8Sinn Left Side Plate for RED® V-Raptor
8Sinn Right & Left Side Plate For RED V-RAPTOR
- two-piece set
- 1/4" mounting points
- Arri locating points (+ 3/8" mounting point)
- Aluminum made
