BRIDGE EX HH - Overview
The Digital Forecast BRIDGE EX HH is a 1 HDMI input to 2 HD/SD SDI output converter module. Using this module allows you to convert HDMI video device signals to a SMPTE standard SDI signal. Formats up to 1080p60 are supported and two SDI signals can be sent out. The converter had a built-in scaler and also features the ability to set the output to a fixed format.
  • Warranty:
    • 2 Years
BRIDGE EX HH HDMI to 3G/HD/SD SDI Converter Module with SCAN Mode
SKU: Bridge EX HH
$570.00Price
    • HDMI to SDI converter
    • 1 HDMI input
    • 2 HD/SD SDI output
    • SCAN converter
    • Improved Output Jitter
    • Input state LED expression
    • DIP switch configuration
