BRIDGE 2000D - Overview
The Digital Forecast BRIDGE 2000D EX Series Rack Frame is a 2RU cost-effective frame with dual power supply that can accommodate up to 10 modules. This frame is designed to be used with the BRIDGE Coverter Series modules. Removing and replacing the modules is easy and utilizes a plug-in method. Network support is featured.
Warranty:
  • 2 Years
Digital Forecast BRIDGE 2000D 2RU EX Series Rack Frame with Dual Power Supply
SKU: Bridge2000D
$1,140.00Price
    • 2RU, 19 standard rack size
    • Up to 10 module capacity
    • NETWORK support
    • Replacing the rear connector of each module is easy
    • 2 pieces attached 200W power supply of sufficient capacity to accommodate 10 modules
    • Removable module features plug-in method
