X-SH - Overview
The X-SH is part of the Digital Forecast Bridge X Series and is an SDI to HDMI converter, supporting up to 1080p resolution. Using this converter will allow you to monitor professional quality SDI signals on consumer-based equipment such as televisions and projectors. Audio information can be lifted from the SDI signal going in and then embedded in the HDMI signal going out by utilizing the external stereo analog audio ins/outs. This converter boasts zero delay conversion and timing.
  • Specifications:
    • Physical
    • Dimension (H x W x D): 70 x 90 x 22 (mm)
    • Weight: 100g
    • Power Level: 7V ~ 17 VDC
    • Power Consumption: 3.5 Watts (Max: 4 Watts)
    • Operating Temperature: -20° ~ 70°
    • Humidity: 0 to 95% RH, non-condensing
    • Data Rate: 3G
    • Signal Level: 800mVp-p +/- 50m Digital Video Specs
    • Supports HDMI v1.3
    • Supports multi-rate SDI formats
    • SMPTE 125M: NTSC (480i 59.94), PAL (576i 50)
    • SMPTE 296M: 720p (60/59.9450)
    • SMPTE-274M, SMPTE-292M: 1080i (60/59.94/50) 1080p (30/29.97/25/24/23.98)
    • SMPTE-424M: 1080p (60/59.94) 3G
  • Warranty:
    • 2 Years
Bridge X-SH 3G SDI to HDMI with Analog Audio MUX & DMX Converter
SKU: X_SH
$151.00Price
