The robust 14.4V, 195Wh, 15A Li-Ion Battery from GENTREE provides power for your camera or pro video accessory. The 15A battery also offers two D-Tap ports and one USB port for powering accessories.
G-B100 series batteries are designed to be both shock- and short-proof, and each features a wireless design that dissipates heat. 10-Step LED remaining-power display aids in timely battery changes.
  • SPECS
Mount / Series Type
Gold Mount
Chemistry
Lithium-Ion
Capacity (Wh)
160 Wh
Amp-Hours
11 Ah
Output Voltage
14.4 VDC
Amps Load
15 A
Accessory Port
2 x D-Tap Ports 1 x USB Type-A Port
Minimum Load (Accessory Port)
D-Tap : 144W, 12A
Terminal : 144W, 12A
USB Output
5 V, 2.3 A
Charging Voltage
16.8 VDC
Charging Temperature
50 to 86°F / 10 to 30°C (Recommended)
Discharging Temperature
50 to 104°F / 10 to 40°C (Recommended)
Dimensions (W x H x D)
5.75 x 3.82 x 2.32" / 146 x 97 x 59 mm
2.35 lb / 1070 g
GENTREE 160Wh / 11Ah Li-Ion Gold Mount Battery (15A)
SKU: G-B100/160W 15A G
$379.00Price
