The robust 28.8V, 160Wh Li-Ion B-Mount Battery from GENTREE provides power for Arri Alexa 35 Camera. The battery also offers two D-Tap ports and two USB C ports for powering accessories.
G-B300 series batteries are designed to be both shock- and short-proof, and each features a wireless design that dissipates heat. 10-Step LED remaining-power display aids in timely battery changes.
Mount / Series Type | B Mount |
Capacity (Wh) | 160 Wh |
Amp-Hours | 5.5 Ah |
Output Voltage | 28.8 VDC |
Amps Load | 12 A |
Accessory Port | 2 x D-Tap Ports 2 x USB C Ports |
D-Tap Output (x 2) | 96W, 6A*16V (Sum of Two D-Taps) |
USB C Output (x 2) | PD3.0 , 60W & PPS Port PD2.0 , 60W port * 5V-3A / 9V-3A / 15V-3A / 20V-3A, 60W and PPS in PD 3.0 Port |
Charging Voltage | 33.6 VDC |
Charging Temperature | 50 to 86°F / 10 to 30°C (Recommended) |
Discharging Temperature | 50 to 104°F / 10 to 40°C (Recommended) |
Dimensions (W x H x D) | 3.94 x 5.75 x 3.81" / 100 x 146 x 97 mm |
Weight | 2.36 lb / 1.07kg |
