The robust 14.4V, 195Wh, 12A Li-Ion Battery from GEN ENERGY provides power for your Gold mount camera or pro video accessory. The 12A battery also offers two D-Tap ports and one USB port for powering accessories.
G-B100 series batteries are designed to be both shock- and short-proof, and each features a wireless design that dissipates heat. 10-Step LED remaining-power display aids in timely battery changes.
Mount / Series Type | Gold Mount |
Capacity (Wh) | 195 Wh |
Amp-Hours | 13.5 Ah |
Amps Load | 12 A |
Accessory Port | 2 x D-Tap Ports 1 x USB Type-A Port |
Minimum Load (Accessory Port) | D-Tap : 84W, 7A Terminal : 144W, 12A |
USB Output | 5 V, 2.3 A |
Charging Temperature | 50 to 86°F / 10 to 30°C (Recommended) |
Discharging Temperature | 50 to 104°F / 10 to 40°C (Recommended) |
Dimensions (W x H x D) | 5.75 x 3.82 x 2.32" / 146 x 97 x 59 mm |
Weight | 2.35 lb / 1070 g |
