Run your Gold-Mount camera or pro video accessory on the G-B100 14.4V, 390Wh Li-Ion Battery from GENTREE. Offering 14.4V power via its Gold mount connection, this robust battery has a capacity of 27.2Ah and supports high-current draws up to 15A. Two integrated D-Tap ports allow you to run accessories directly from the battery, and a USB interface allows you to charge your smartphone and other electronic devices while shooting.
Mount / Series Type | Gold Mount |
Capacity (Wh) | 390 Wh |
Amp-Hours | 27.2 Ah |
Min. Discharge Power | 180 W, 15 A |
Accessory Port | 2 x D-Tap Ports 1 x USB Type-A Port |
Min. Discharge Power (D-Tap Port) | 144 W, 12 A (D-Tap) |
USB Output | 5 V, 2.3 A |
Weight | 4.5 lb / 2040 g |
Package Weight | 5 lb |
Box Dimensions (LxWxH) | 7.2 x 5.0 x 5.1" |
