The robust G-B200 14.4V, 290Wh Li-Ion Batteryfrom GENTREE provides power for your V-mount camera or pro-video accessory. The 20Ah G-B200 battery also offers two D-Tap ports and one USB port for powering accessories.
G-B200 series batteries are designed to be both shock- and short-proof, and feature a wireless design that dissipates heat. A 10-LED gauge remaining-power display aids in timely battery changes.
Compact, shockproof, and short-proof designCable-free design minimizes heat, prolonging battery life10-LED gauge displays remaining powerTwo D-Tap ports and one USB port for powering accessories
Capacity (Wh) | 290 Wh |
Amp-Hours | 20 Ah |
Accessory Port | 2 x D-Tap 1 x USB Type-A |
Maximum Load (Accessory Port) | 5 A ( D-Tap ) |
USB Output | 5 V, 2.3 A |
Charging Temperature | 32 to 104°F / 0 to 40°C |
Weight | 3.3 lb / 1520 g |
Packaging Info | |
Package Weight | 3.85 lb |
Box Dimensions (LxWxH) | 7.4 x 4.9 x 4.1" |
