Run your V-mount camera or pro video accessory on the G-B100 14.4V, 290Wh Li-Ion Battery from GENTREE. Offering 14.4V power via its V-mount connection, this robust battery has a capacity of 20Ah and supports high-current draws up to 22A. Two integrated D-Tap ports allow you to run accessories directly from the battery, and a USB interface allows you to charge your smartphone and other electronic devices while shooting.
Compact, shockproof, and short-proof design
Cable-free design minimizes heat buildup, prolonging battery life
Five-LED gauge displays remaining power
Two D-Tap ports and one USB port for powering/charging accessories
Capacity (Wh) | 290 Wh |
Amp-Hours | 20 Ah |
Maximum Load | 264 W, 22 A |
Accessory Port | 2 x D-Tap Output 1 x USB Type-A Output |
Maximum Load (Accessory Port) | 144 W, 12 A ( D-Tap ) |
USB Output | 5 V, 2.3 A |
Weight | 3.3 lb / 1520 g |
