The robust G-B100 14.4V, 390Wh Li-Ion Battery, called as MONSTER battery, provides power for your large foramt camera and LED lights demanding high power Watts. The 27.2Ah G-B100 battery also offers two D-Tap ports and one USB port for powering accessories.
G-B100 series batteries are designed as shock- and short-proof, and feature a wireless internal PCB design that dissipates heat. A 10-LED gauge remaining-power display aids in timely battery changes.
  • SPECS
  • Packaging Info
Mount / Series Type
V-Mount
Chemistry
Lithium-Ion
Capacity (Wh)
390 Wh
Amp-Hours
27.2 Ah
Output Voltage
14.4 VDC
Min. Discharge Power
312 W, 26 A
Accessory Port
2 x D-Tap Ports 1 x USB Type-A Port
Min. Discharge Power (D-Tap Port)
144 W, 12 A (D-Tap)
USB Output
5 V, 2.3 A
Charging Voltage
16.8 VDC
Storage Temperature
-4 to 104°F / -20 to 40°C
Charging Temperature
50 to 86°F / 10 to 30°C
Discharging Temperature
-4 to 122°F / -20 to 50°C
Dimensions (W x H x D)
5.8 x 3.8 x 3.1" / 146.0 x 97.0 x 78.0 mm
4.5 lb / 2040 g
Package Weight
5 lb
Box Dimensions (LxWxH)
7.2 x 5.0 x 5.1"
GENTREE MONSTER 390Wh / 27.2Ah Li-Ion V-Mount Battery (26A Max. Discharge)
SKU: G-B100/390W 26A
$729.00Price
