HD&P CFOS 4K+S_1CH Overview
HD&P’s CFOS 4K+S_1CH System transforms cinema cameras into broadcast-ready cameras, enabling the transmission of power, video, intercom, tally, data, genlock, and other critical functions over long distances using SMPTE fiber optic cables.
This advanced system is designed to meet the demands of 4K Cinema cameras and 4K camcorders, ensuring seamless integration into broadcast environments.
The Camera Adapter (CFOS 4K+S CA) easily attaches to the camera’s battery mount, converting it for broadcast use. The CFOS 4K+S_1CH configuration controls single camera, offering a powerful and flexible solution for professional broadcasting needs.
1. Supports 20-pin circular connector for Sony viewfinder monitors
(Transmits monitor power, camera and return component video, and tally functions on a single strand of cable)
2. Supports outputs for common viewfinder monitors (circular connector for power
and tally, BNC connector for camera and return SDI video output
3. RCP data support (RS422)
4. Intercom support (microphone on/off and volume control)
5. Red and green tally LED indication (on/off and adjustable brightness)
6. Support for Zenlock signals (Tri-level & BB level)
7. 100 Mbps Ethernet support
8. Optical signal power verification LED indication
9. AUX Video OUT (3G/HD-SDI) support
10. Optical trunk support (ST/PC)
Base Station (CFOS 4K+S BS)
1. Configures up to 4 cameras
2. Moduler slots for easy addition up to 4 cameras
4. 3 ports of 12G SDI output and 1 port of downstream (3G/HD SDI) output each camera
5. Support for common PGM return video input and loop out
6. Support for per-channel AUX video input (3G/HD-SDI)
7. Genlock signal input and Loop out support (Tri-level & BB level)
8. Intercom support (volume control and two inputs and outputs) (supported with optional internal intercom board)
9. Built-in port for external intercom equipment interworking or additional CFOS intercom interworking equipment support (2 -wire or 4-wire selectable - supported with optional internal intercom board)
10. 100 Mbps Ethernet support
11. One optical TX/RX support (ST/PC) on each camera
12. Built-in tally signal integration port
13. Built-in independent electrical safety breakers per camera
14. Optical signal power verification LED indication
