Run your Gold mount camera or pro video accessory on the G-B100 14.4V, 160Wh Li-Ion Battery from GENTREE. Offering 14.4V power via its Gold mount connection, this robust battery has a capacity of 11Ah and supports high-current draws up to 12A.
Compact, shockproof, and short-proof design
Cable-free design minimizes heat buildup, prolonging battery life
Mount / Series Type | Gold Mount |
Capacity (Wh) | 160 Wh |
Amp-Hours | 11 Ah |
Accessory Port | 2 x D-Tap 1 x USB C Port (PD 65W/Charge & Discharge) |
Maximum Load (D-Tap Port) | 12 A ( D-Tap ) |
USB C Port | PD+PPS 65W Charge & Discharge |
Dimensions (W x H x D) | 5.8 x 3.8 x 2.3" / 146.0 x 97.0 x 59.0 mm |
Weight | 2.43 lb / 1100 g |
