Run your Gold mount camera or pro video accessory on the G-B100 14.4V, 195Wh Li-Ion Battery from GENTREE. Offering 14.4V power via its Gold mount connection, this robust battery has a capacity of 13.5Ah and supports high-current draws up to 12A.
Mount / Series Type
Gold Mount
Chemistry
Lithium-Ion
Capacity (Wh)
195 Wh
Amp-Hours
13.5 Ah
Output Voltage
14.4 VDC
Accessory Port
2 x D-Tap 1 x USB C Port (PD 65W/Charge & Discharge)
Maximum Load (D-Tap Port)
12 A ( D-Tap )
USB C Port
PD+PPS 65W Charge & Discharge
Charging Voltage
16.8 VDC
Storage Temperature
-4 to 104°F / -20 to 40°C
Charging Temperature
50 to 86°F / 10 to 30°C
Discharging Temperature
-4 to 122°F / -20 to 50°C
Dimensions (W x H x D)
5.8 x 3.8 x 2.3" / 146.0 x 97.0 x 59.0 mm
2.43 lb / 1100 g
OLED Display - GENTREE G-B100 14.4V, 195Wh Li-Ion Gold Mount Battery (12A)
SKU: G-B100/195W 12AD G
$419.00Price
