Run your V-mount camera or pro video accessory on the G-B100 14.4V, 290Wh Li-Ion Battery from GENTREE. Offering 14.4V power via its Gold mount connection, this robust battery has a capacity of 20Ah and supports high-current draws up to 15A.
Compact, shockproof, and short-proof design
Cable-free design minimizes heat buildup, prolonging battery life
Mount / Series Type | Gold Mount |
Capacity (Wh) | 290 Wh |
Amp-Hours | 20 Ah |
Accessory Port | 2 x D-Tap 1 x USB C Port (PD 65W/Charge & Discharge) |
Maximum Load (D-Tap Port) | 12 A ( D-Tap ) |
Weight | 3.4 lb / 1540 g |
