Run your V-mount camera or pro video accessory on the G-B100 14.4V, 390Wh Li-Ion Battery from GEN ENERGY. Offering 14.4V power via its V-mount connection, this robust battery has a capacity of 27.2Ah and supports high-current draws up to 15A.
Capacity (Wh) | 390 Wh |
Amp-Hours | 27.2 Ah |
Min. Discharge Power | 180 W, 15 A |
Accessory Port | 2 x D-Tap Ports 1 x USB C Port / PD65W Charge & Discharge |
Min. Discharge Power (D-Tap Port) | 144 W, 12 A (D-Tap) |
USB C Port | PD+PPS 65W Charge & Discharge |
Dimensions (W x H x D) | 5.8 x 3.8 x 3.8" / 146.0 x 97.0 x 97.0 mm |
Weight | 4.5 lb / 2040 g |
