Run your V-mount camera or pro video accessory on the G-B100 14.4V, 290Wh Li-Ion Battery from GENTREE. Offering 14.4V power via its V-mount connection, this robust battery has a capacity of 20Ah and supports high-current draws up to 22A.
Compact, shockproof, and short-proof design
Cable-free design minimizes heat buildup, prolonging battery life
Capacity (Wh) | 290 Wh |
Amp-Hours | 20 Ah |
Maximum Load | 264 W, 22 A |
Accessory Port | 2 x D-Tap Ports 1 x USB C Port / PD65W, Charge & Discharge |
Maximum Load (Accessory Port) | 144 W, 12 A ( D-Tap ) |
USB C Port | PD+PPS 65W Charge& Discharge |
Weight | 3.4 lb / 1540 g |
