Postium Korea OBM-H210 Overview
Monitor your production in the studio, on the field, and even in broad daylight with the OBM-H210  21" Super Bright Daylight Viewable LCD Monitor with 3G-SDI from Postium Korea. With 1920 x 1080 display resolution and a 178° viewing angle, the monitor boasts a brightness of 1500 cd/m² and a 1000:1 contrast ratio. It features two 3G-SDI inputs and two 3G-SDI outputs, one HDMI 1.3a input and one output, which all provide options for bringing in video with embedded audio, while a 3.5mm line input offers analog stereo connectivity. A 3.5mm analog stereo output allows you to monitor sound via optional headphones. There are also component and composite inputs for analog video. The monitor comes with its own power cord.
High Dynamic Range (HDR) Emulation applies a High Dynamic Range display gamma curve to HDR content. The OBM-N310-NB supports PQ EOTF (SMPTE ST 2084), Hybrid Log Gamma and S-Log3. Postium's HDR function allows you to view both highlights and shadow details within scenes simultaneously, thus resulting in more natural and realistic reproduction. SDR/HDR Display modes provide both full-frame HDR and SDR viewing as well as simultaneous side-by-side split screen comparison.
Focus Assist controls the aperture level of a video signal and displays images on screen with sharpened edges to help camera focus operation.  False Color indicates the luma (Y) level of the input image. If a certain Y level is set, the pixels with the designated Y level are displayed with a zebra pattern or a color pattern. There are multiple display modes: Zebra, Variable, ARRI, and Comparison.
n-Monitor Display (IMD) allows image source names and tally information to be displayed on the screen with an external remote function via Ethernet. TSL system protocol is supported. The color of the source name and tally color is selectable among white, red, green, blue, yellow, cyan, and magenta.
  • Postium Korea OBM-H210 21" Super Bright Daylight Viewable Monitor
  • Limited 1-Year Manufacturer Warranty (LCD Panel)
  • Limited 2-Year Manufacturer Warranty
SKU: OBM-H210
$4,235.00Price
