Postium Korea OBM-L180 Overview
The OBM-L180 18.5" Entry-Level 3G-SDI Monitor from Postium Korea is a full-featured HD/SD broadcast and motion picture production monitor that accepts signals at up to 1080p60. It features a 3G/HD-SDI input and 3G/HD-SDI output interface and an HDMI 1.3a input. The monitor boasts a 178° angle of view, 350 cd/m² brightness, and a 1000:1 contrast ratio, and it comes with its own power cable.
High Dynamic Range (HDR) Emulation applies a High Dynamic Range display gamma curve to HDR content with support for PQ EOTF (SMPTE ST 2084), Hybrid Log Gamma, and S-Log3. The HDR function allows you to view both highlights and shadow details within scenes simultaneously, thus resulting in more natural and realistic reproduction. SDR/HDR Display modes provide both full-frame HDR and SDR viewing as well as simultaneous side-by-side split screen comparison.
Focus Assist controls the aperture level of a video signal and displays images on screen with sharpened edges to help camera focus operation.  False Color indicates the luma (Y) level of the input image. If a certain Y level is set, the pixels with the designated Y level are displayed with a zebra pattern or a color pattern. There are multiple display modes: Zebra, Variable, ARRI, and Comparison.
Built-In Camera Log to Linear Conversion LUTs
The monitor has built-in Camera Log to Linear Conversion LUTs from various camera manufacturers, including Log-C, C-Log, S-Log2, S-Log3, J-Log1, and more. Plus, custom 3D LUTs can be imported for accurate and consistent color matching between different displays and for DIT previews of customized 'looks' that have been created by third party color-grading applications. The LUT-converted content can then be output to downstream devices/monitors via the SDI loop out.
  • Postium Korea OBM-L180 18.5" Entry-Level 3G-SDI Monitor
  • Limited 2-Year Manufacturer Warranty
SKU: OBM-L180
$2,433.00Price
